Hello;
I had a few days ago a problem with my meter.
Needles with zero as well as all the lights or off randomly.
I was able to see that it was a concern of battery.
I then reloaded it now everything work normally or almost.
I have two error my light of preheating (maybe others I am not sure there) do not ignite any more,
but I also have the screen ignites puts me " the time" twinkling but impossible to reach the menu and does not indicate the outside temperature.
I thus verified the follow - function works me the regulation of plate of lighthouses also thus I suppose that the screen is not in question.
When my dashboard "resets", it is with a noise I think that it is a relay you would be which one to verify Or if I would have to clean completely the fusible door at the level of the battery?
I would want to know if with my concern which lasted several in the daytime I would have " breack " something?
I am anxious to inform that I have the semi regulator to cable that I cut the cables of the brown connector to bring them inside the vehicle (but the regulator does not work) I do not know if his exchange diagnoses it, but I prefer to specify it
Sorry for my bad english i m french
