| | Thread Tools | Search this Thread |
Posts: 3 Thanks: 0 Trader Rating: 0 | multimeter test of brake light switch Hi I have followed the guide on testing the brake light switch using my multimeter, I am though in doubt about the result. The switch has 4-poles, and only the one pair responds when I press the switch. Is this how it should be if it is working ok? I have had a lot of engine fault, ASR, alternator error and loose connections errors and now it was clearly associated with activation of the brake. Perhaps the brake light switch is part of the problems. My car: fiat stilo dynamic 2002, 1.6 16v All the best and thanks
| | Quote
Posts: 3 Thanks: 0 Trader Rating: 0 | Re: multimeter test of brake light switch Well, just replaced with a new one, which responded in the same manner on the multimeter test. No difference neither on the car, still it reports loose connection when I press the brake and in addition the panel lights up with almost all alarm lights while it beeps 'loose connection' repeatedly. But once in a while I can activate the brake without errors so apparently there is a loose connection somewhere. Any comments are really appreciated.
| | Quote
| | #3 |
Posts: 8,331 Thanks: 990 Trader Rating: 1 | Re: multimeter test of brake light switch Did you adjust the switch correctly after fitting it? .
__________________ Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) + Croma Turbo i.e. Badges. For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514 |
| | Quote
| | #4 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 | Re: multimeter test of brake light switch ups, forgot that, thanks!. Just did so following the guide. Lights works ok, but still complaints about loose connection.
| | Quote
| | #5 |
Posts: 8,331 Thanks: 990 Trader Rating: 1 | Re: multimeter test of brake light switch The loose connection warning message and multiple warning lights can appear if the battery is faulty, or not fully charged. .
| | Quote
| | dave | Idea | 2 | 21-08-2011 22:00 |
| | beecon | Cinquecento / Seicento | 18 | 21-04-2011 23:12 |
| | Richy BoyUK | Bravo / Brava | 2 | 16-12-2010 19:07 |
| | jjjdup | Stilo | 1 | 28-05-2009 07:07 |
| | PaulBrad | Uno | 4 | 29-11-2005 18:39 |
