was fuse ok also F21
mine is a multiwagon stilo so was just a case of lifting the rear seat base forward part of design to make more load space not sure of the car version, then tank fuel pump was clearly visible and easy to access.tap plastic outter ring off and fuel pump comes out there are locating lugs when re-fitting so it only goes back the right way and a sealing gasket that needs to be seated right just few points to look out for if it comes to removing tank fuel pump which with seat base out of the way you should certainly be able to hear whirring when ignition on when all power is back to normal
When I check my fuel line for fuel it was the centre line pointing forward connected to fuel filter and also when you get to tank fuel pump with switching ignition on you will only be abl;e to read voltage on the thicker tank fuel pump wires for few seconds, as it kills the power if engine not running other thin wires are just the fuel gauge sensor wires
ooh and the tank fuel pump is roughly central position under rear seat, with pre-cut carpet as cover then black plastic cover
