Hello.I'm back.This time with some improvements,but I am not 100% satisfied.I finally found the right sizes of the springs.Changed the alloys and tyres.And finally went for a 4-wheel alignment.Before I had done the alignment the steering was pretty light.After the alignment it went harder,and the car is very hard to control.The steering is like a spring.I turn left and if I leave the steering it will come as the initial form very fast.I have to fight with the steering wheel all the time.This thing was like that since the genuine front springs broke.The spring are aligned as it should be.The bearing is fit as it should.The only thing I did not manage to understand is:why does the top rubber mounting does not turn when the strut is off the car.I tried with the old parts that I have,but still nothing.The only thing I did not changed is the lower rubber mounting.Can that be the cause why is not turning?Thanks
