Clutch...
This week, I replaced a clutch in another Abarth - Selespeed - this one had already been done a couple of years ago, but a diaphragm spring finger had cracked.
I reckon most Abarths now will be up around 125,000km (~75,000 miles) which seems to be when the clutch needs doing. Symptoms are a generally jerky/grabby gearchange particularly into 2nd and 3rd, high revs when manoeuvring slowly in 1st and reverse, and of course, slipping when it gets really bad.
Connecting with
MultiECUScan and an ELM327 cable (I reckon an essential tool for all Stilo owners, the 21st-century equivalent of a points file and timing light) you'll find the clutch degradation index will be up around 12000 (ranges from -4000 for a theoretical better-than-perfect clutch to 14000 for worn-out). You can obviously check this before buying and use as a bargaining point (in England, I expect replacing the clutch will nearly double the value of the car...)
As clutches go, the parts are relatively expensive - release bearing is concentric with an electronic sensor (£150+?) and clutch disc and cover is also on the pricey side (£250+?). Having replaced my dual-mass flywheel (£400-ish), I'm not completely convinced that is necessary to replace. Not being a diesel, I don't think it will rattle badly even if loose. I took one off another engine that had slight play, yet the engine seemed smooth. I replaced that one with the old one off my car. Time will tell.
Working around the gearbox seems rather tight but at least it is easy to drop the subframe. Still, I found it was a ten-hour job to replace the clutch...
The Selespeed itself seems to give little trouble relative to the first-generation Selespeed in the Twinspark Alfa 156 and 147.
The bodyshell is a generation newer than the Bravo/Brava, and feels it. Better rigidity, very low engine noise, low wind noise, reasonably low tyre noise. Some nice modern materials in the interior and some cheaper materials too. The standard Connect Nav+ seems obsolete now but at least you have a double-DIN hole to work with.
I think the Abarth is a pretty safe car by any standards. Wide tyres give lots of grip and there are electronic safety aids (traction control, stability control, brake assist, etc.) Slightly woolly electric steering (not 'lively' but secure-feeling, except on some rough surfaces where the column seems to develop a shudder).
The steering and handling of these cars is not up to Alfa Romeo standards (at least not in standard Abarth form - lower and stiffer suspension is available and reasonably-priced) but if you're looking for more of a comfortable cruiser then you'll probably be impressed, especially compared to a smaller Fiat such as the Punto. 'Abarth' probably wasn't the right name, 'Stilo GT5' would have been more appropriate! It is a great touring car, good economy for the performance, and the five-cylinder engine really makes the car.
Did I mention that it's worth checking the clutch?
-Alex
