Technical car shakes
andrewdxx
hi just bought a fiat stilo 1.6 16v problem i have with it is
the engine light is on half the time its flashing other times its on solid, air bag fail, high oil preasure comes on now and again all dials go all the way up then back down, bulb failed light but bulbs work fine, traction control light on, stop engine sign, engine shakes all the time makes the car shake like hell more when just sitting there or putting foot down, when doing say 70 mph on motorway all of a sudden the car just drops down to 40 mph for no reason
i have had spark plugs changed and one of coil packs
had engine codes read but garage said they have never had a car that changes its codes every time they plug it in first time was 13 faults then went to 4 then 20 all diffrent faults
does anyone have any idea what it might be
Ecu
Hi just a quick stupid question
I have been told i need a new ecu
Now I have looked on ebay and I can on get a ecu with the part number
Iaw 5nf.t9 the problem is mine says iaw 5nf.t1
Can I use t9 or do I need to find a t1
Re: Ecu
You'll need to find a t1, chances are if you get a t9 it won't work and you'll have one dead car and be out of pocket, your best bet is to go to your nearest parts centre/ fiat dealer and ask them to find you one. At least you'll know it will work if its identical.
