Hi all!
Am a newbie to Fiats after a long affiliation with Alfas (pretty much the same thing!)
Just bought a Stilo 1.2 16v on a 52 plate with a couple of issues - was wondering if anyone could suggest a remedy?
Intermittent engine fault comes up - it does clear with fiat ecu scan but ultimately comes back. Also have airbag light and bulb blown light which randomly appear?
Was wondering if these faults are a related electrical issue rather than three true problems? From my stint with Alfas, I'm well aware of the reliabilty (hmmm) of Italian car electrics!
Fault codes for engine and airbag (before I cleared them) are below:
Engine:-
U1600 ------ Invalid signal stored
P1688 Electrically actuated throttle (idle learn 2) -- invalid signal stored light on
P1689 Electrically actuated throttle (self compensation) -- invalid signal stored light on
Airbag:-
32 Front passenger weight sensor -- unknown/internal error intermittent 130
32 Front passenger weight sensor -- open circuit/short circuit at v+ battery intermittent 25
02 ecu supply voltage -- value too low intermittent 19
Although cleared they all come back! Was wondering if anyone could shed some light on a cause and remedy?
According to the previous owner there is also a drain on the battery if car is left for a couple of weeks - could this be related?
Oh, and probably not related but thought I should mention - these faults appeared shortly after a cambelt and water pump change 1000 miles ago....
Thanks for any help, in advance
Engine:-
Airbag:-
