silver rocket
- Nov 11, 2012
- 23
- 7
hi all hope somone can help here.. here's whats after happening
Last week the gearbox mount at the side broke letting the engine drop and fall forward looked like the engine had fallen out ....previous owner must have snapped two bolts in the gearbox when fitting a gearbox or clutch only leaving one in it and that broke i have drilled the old bolt holes out re-tapped them fitted new bolts a new mount engine is back up where it should be
now my problem is i have everything bolted back in place i had to remove the battery box and disconnect a few of the wires around the fuse box just to get the battery box out.
All is connected up right no wires are missing
i did all this and went to try start car and nothing the car turns over but doesnt fire there is absolutely no dash lights not interior light absolutely nothing.
Its like the car is dead inside if i try the key a small bit the lights around below the heater controls barely flicker air con one and airbag dah light barely flicker
