I keep losing pad retaining clips. It only happens on one side (drivers rear). It also makes an irritating noise. I'll go under the car, remove the caliper, see that a couple of pad clips are missing, replace them and put it back together. It will drive fine for a while but then the noise will slowly come back again, starting with a quick squeaking noise then later turns into a clicking.
I'll go back under the car again, unbolt the caliper and remove the pads to find that 3 pad clips are gone having previously fitted 4 in there! I've now run out of spare pad clips and the noise is just a little bit infuriating. What is causing these pad clips to come out?! It only happens on the drivers rear. Also the wheel on that side is slightly buckled, not sure if it's related?
Mark
Mark
