Thread Tools
Old 06-03-2013   #1
heater not hot again
Hi my heater is not getting hot , my temp gauge stays in the middle when standing still and only moves slightly down and up when moving but only down to the first line above quarter so i don't think its the thermostat , when standing still the water pipe going into the heater is red hot the pipe coming out is Luke warm just like the heater it only gets luke warm i can not find a bleed screw on the back of the engine anywhere please help
owner511 is offline Reply With Quote Quote
Old 06-03-2013   #2
Re: heater not hot again
-- its a 1.4 , 60k on the clock , 2004 plate
Old 06-03-2013   #3
Not sure about the 1.4 but my 1.2 has a bleed screw (black plastic) mounted in a hose behind the throttle body.
hope this may help ?
StiloBoo is offline Reply With Quote Quote
Old 06-03-2013   #4
Yellow Peril has donated!
Probably an air lock. System needs bleeding.
Phil
Yellow Peril
Then:Yellow Stilo 1.6 16V 3-door - not quite standard
Now: Red Stilo Abarth Schumacher GP Prodrive - modded for function over form...
Yellow Peril is offline Reply With Quote Quote
Old 06-03-2013   #5
thanks i cart find the one on the back, only the top of the rad ?
Old 06-03-2013   #6
rpm711 is offline Reply With Quote Quote
Old 07-03-2013   #7
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Bolivia
Your thermaostat is fault if the temp gauge drops at all, but you should still get heat when it's sitting in the middle. I don't think my 1.4 had an upper bleed screw. Possibly a blockage in the system?
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
2 White Classic Panda Selecta's, 1989 Panda 750L,
2013 Toyota Prius Plug-In & 2009 Panda Eleganza
Most Easterly Pandas is offline Reply With Quote Quote
Old 07-03-2013   #8
StiloBoy has donated!
Indeed sounds like your thermostat!
Ex- 53 plate, Stilo 3-door, Sassy grey, newly refurbished 17" Claw Alloys, Avon ZV5 tires, 1.2 Active
http://www.fiatforum.com/gallery/data/500/26348.png
StiloBoy is offline Reply With Quote Quote
Old 07-03-2013   #9
Mine had the same problem, I put a stat in, no difference I cured it by flushing water through heater matrix about 4 times. That sorted it right out.
Stilo man is offline Reply With Quote Quote
Old 08-03-2013   #10
Maigretnz has donated!
New Zealand
Just be careful when flushing matrix with hose as mains pressure is a lot more than found in a car's cooling system.
Maigretnz is offline Reply With Quote Quote
Old 08-03-2013   #11
Trader Rating: 2
Bolivia
Quote Originally Posted by Maigretnz View Post
Not in the UK, we're not lucky enough to have pressure washer hoses off the mains, or I'm not anyways
Old 09-03-2013   #12
New Zealand
Indeed. But in all seriousness I have seen cores wrecked by putting hose on them. Mains is typically 40-60 psi (3-4 bar) but the car's cooling system is 10-15psi (1 bar)
Old 09-03-2013   #13
Trader Rating: 2
Bolivia
I know my mains supply isn't 3-4 bar, only about 1-1.5 at best at mine.
Although a quick search reveals its anywhere between that and 3 bar for different parts of the UK.
Old 27-04-2013   #14
Just an update on this! I replace my thermostat today and my temp is bang in the middle again and toasty hot heater again!
My technique for getting rid of air in the system was leave expansion bottle lid off. Start car and let I run and warm up. There was still a airlock somewhere so I squeezed the pipe coming out of the thermostat a couple of times and this pushed coolant into the expansion tank! The airlock soon followed and bubbled up in the expansion tank!
Jobs a good 'un!
Likes Most Easterly Pandas liked this post
Thread Tools
Heater - how hot is hot ? toodlepip Ulysse 4 04-11-2012 12:49
(T) heater blows hot or hot... no cold or warm just HOT. Alfizzle Panda (Classic) 14 15-10-2009 21:01
(G) Heater blowing hot! Slippy Cinquecento / Seicento 19 27-07-2006 21:31
(T) Interior heater ,very,very hot mark1 Cinquecento / Seicento 2 06-07-2006 01:04
