On Tuesday night I had to travel about 200km to Turangi, which is a little way around Lake Taupo (say: toe-paw) in NZ's north island.
I was running a training course so the distance is reimbursable. With its huge boot and comfy ride, the Stilo was earning its keep. I drove down using the cruise control and resisted the temptation to flex the engine's muscles, carefully stuck to the 100km/h speed limit. Average speed was 85km/h and average fuel consumption 8L/100km which is about 35mpg. Not bad (not quite as good as my 2003 156 Selespeed, which would easily get down to 7L/100km and less).
While I was down in Turangi, major roadworks started around the eastern side of the lake. Delegates on the course suggested I drive back towards Taumaranui and through to Whakamaru. So I did.
It had been a long two days and I was in danger of falling asleep even though it was a bright and sunny 5pm. The twisty road through the hills ensured that I didn't! The Stilo was rolling and squirming into corners quite a lot (must get those Eibachs and Bilsteins ordered...) Then the road opened out a bit and I decided to go for it.
Speeds were so high that for a whole hour I averaged 105km/h - the 2.4 is effortless, and sounds so great over 4000rpm in fifth. The handling became a kind of guided missile as the floating and pitching reached epic levels, but it was all very exciting. I haven't had such excitement for a while. The tail wags if you brake in a corner, which I only did because I saw another car up ahead (it was the only one though).
In the photo I'm waiting to drive over a hydro dam.
The surprise? Average fuel consumption for this section of the trip (I had reset it) was 9.8L/100km which is about 27mpg and I think that's amazing. An increase in average speed of 23.5% gave an increase in fuel usage of 23.5%. How is that possible? The aerodynamics must be fantastic (aerodynamic drag increases as a square of the velocity) - and the top speed was nearly double what was reached before.
So in a Stilo Abarth, if you haven't died, killed someone, or lost your license and appeared in court, at least you've got good fuel economy at high speeds. I don't think you can do that with a smaller engine.
Back on the main road at Tokoroa, I resumed my gentle cruise at 100km/h (it felt very slow indeed) and from there to home I passed three drivers pulled over by police - they had probably been doing 120km/h. I was glad to be able to do the right thing having actually 'lived' for an hour.
Yesterday I drove all around the Coromandel in my Uno Turbo and even at speeds well below 100km/h it often felt extremely dangerous. I think I was doing 80 or less most of the time.
-Alex
-Alex
