My Stilo (1.6) has developed some sort of disease, and I am struggling to find out what it is.
First:
For many months now, perhaps almost a year (as I didn't quite notice), the engine temp has never been on top for long, before it falls one "notch" and then pretty fast climbs up again. Usually it will stay just between top and the notch to the left. It never overheats, so thats's alright. The coolant is under 2 years, and not a drop is lost.
Second:
A couple of months ago, a coil said goodbye, and was changed. FES stated a faulty injector, but this moved along with the faulty coil as I did a swap test. Two weeks later, a new coil went, but in the meanwhile I had ordered a new set of 4. So I changed all to the new set, keeping the first change as a spare (again). Then it was alright again, with no faults.
Third:
The car has used more fuel than usual. Not in city driving, but on long trips, perhaps 20% more. It also smells gasoline on startup, and excess smoke when the car idles - and very cold outside. It does not use any oil.
Fourth:
The car has (since around the coil change) had a little lump / jerk, barely noticeable when doing this: Giving full throttle in high gear, with too high gear, lets say you drive in 60 km/h (45 mph), the road is almost flat, and you gear up from 4th to 5th - then when you hit the pedal it produces a small jerk. Not after, just when you hit the gas.
Fifth:
Engine does not sound too healthy, but that might be just me. It idles nicely, but sounds a bit rough.
Sixth:
Yesterday the jerk happened again, and the engine light came on. "Engine management control failure, return to dealer" or something like that. Hooked up FES and I got p0203, injector fault on cylinder 3. Cleared the fault, and haven'd done anything more as it was cold, dark and late.
Before I get any not-so-great ideas, I was hoping someone else could give me some starter-clues.
Morten.
First:
Second:
Third:
Fourth:
Fifth:
Sixth:
Morten.
