General YATOUR CDC emulator - Connect Nav
A Hitman
Probably broken down
Auckland
Hey All,
Has anyone used one of those YATOUR CDC emulators with the Stilos Connect Nav?
ebay.com/itm/110920328270?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
yatourcarkits.com/ytm06-yatour-digital-music-changer-bluetooth-module-optional-p-96.html?zenid=uuf8020hn4kr0ohasmiek3g8n2
Seems pretty cheap if it works, getting pretty sick of swapping out cds (and the fact that every mp3 cd I make skips constantly).
Have tried a couple of FM transmitters which did not work at all, unless they are on the roof next to the Ariel...
I have a Yatour, It works fine. Remembers the track position and has multiple input options such as; SD-card, aux and usb support. Only minor thing is that sometimes the connect nav won`t recognize the Yatour when you start the engine. You can prevent this by starting within 2 seconds after you switch to MAR. Then it will always recognize the device.
Sounds like pretty good feeback so far.
Where did you guys buy your ones from, ebay?
Either of you get the bluetooth kit too?
My yatour device works fine, i am very happy with it, but same problem as above, when i start the engine, i need to reboot my connect nav unit in order to be recognized again.
When i switch to MAR, everything starts out, my yatour is recognized and it's working, but when i start the engine, he loses power somehow and my nav shows no cd in cd changer untill i reboot the unit and everything back to ok.
Any idea how can i solve this little bug?
