Technical Temp on engine unstable
menola
More trouble with temp. When the car is in IGNITION, not engine on, temp is unstable in dash. How can I fix this? Have already changed temp-sensor.
Regards
menola
The temp dail is moving up/down when engine is not running.
/m
Hi, can the ECU lose software update after battery change? /M
I have an idea, if battery is broken the light will light less when fan kicks in. Could generator be broken? How can I test it?
What type of model/generator will fit 1.6 dyn 3door with AC?
/menola
Throttle was jamming, half open. Almost stuck when it tries to open it by hand. Took the throttle appart and oiled it. Sprint is ok. The car more awake now. I have used FiatECUscan 3.6.2 and tested coil. Seemes ok!? Fan is ok. Injectors are ticking with the test. B1684/P1687/P1220 are gone now. The car is still sometimes unsteady. I hade switch coil one by one with another coil and still little unsteady.
/menola
