General Searching for a new 17" Blade Alloy
monkeyknut
Does anyone know where I might be able to get hold of a single blade alloy for my Stilo, preferably in the East Anglia area?
I hit a pothole in the dark a couple of days ago, I thought I had got away with it, until a flat tyre this morning revealed a rather large crack in the inside rim of the wheel.
I have tried eBay, but the only wheels on there at the moment are for a full set of 4 and don't finish until next week.The Stilo is the car I use for my daily commute so I was hoping to find a solution over the weekend. I've also tried all the local breakers yards I could find with no luck, any suggestions would be appreciated as I really don't want to be using the space saver for more than a day or two.
Thanks.
Thanks.
Try a fiat dealer they should still stock them?
If not you may have to be patient and see if something comes up on ebay or from a brakeyard, but then again very unlikely they would sell just one unless others are crashed or something
Fiat do indeed still sell them, for the princely sum of £368.55 each, I nearly fell off my chair! Could get a whole set of 4 of another style for less than that.(n)
Thanks for all the suggestions. Unfortunately I don't think welding was an option, it was a big crack. Not entirely surprising, I hit the pothole at about 60mph and it sounded expensive, I thought I'd had a blow out or the wheel had come off! :eek:Luckily there seems to be no damage to the axle or suspension.
I managed to get a set of four off ebay for £90 and they all look in excellent nick. I think I might replace both front wheels and I'll have a couple of spares, so if anyone on here is in a similar situation in the future, drop me a pm, I might be able to help!
I may be in a similar situation!! Car in for MOT today, failed on a "bulge" to the inside of the drivers front alloy. To be honest, im not so sure its that bad, as the tyre isnt going flat (although it does loose air time to time). I should find out tomorrow if i need a replacement, anything you can do?
***hang on...forgot what size wheels i have!!
