Have anyone any practical guide/advice on how to change the rear brake discs in stilo multiwagon (2007)? - Also, I should change the tie rod ends - any guidance to this operation?
Jack up car safely, putting the car in first and wedging the front wheels, take the hand brake off.
Remove the wheel
Remove brake calliper with two bolts behind the calliper
Remove the two wheel locating pins on the front of the disc and the disc will pop right off.
Reverse and repeat.
NOTE: If there has been considerable wear to the discs on the car then you may need to push the brake calliper pistons back a touch which will require a calliper wind back tool.
