cheesequarterpounder
Greetings ....
I've been through this loop before, with instrument cluster failure - eventually curing the matter with a s/h complete cluster unit. Problem solved.
So, I'm quite familiar already with the usual problems.
This one may be different.
All the instruments in the cluster work, except the speedo itself.
When the key is put in the ignition, the needle on the speedo jumps and settles on 0mph, which suggests that power is getting there.
A message flashes up on the unit, saying that there's a "loose connection" somewhere.
I've done all the usual things like look at all the fuses (inc those under the battery cover) and jiggled all the plug-in components just in case there's a dry joint somewhere.
To complete the picture, the odomiter has also ceased to register any further mileage ...
This suggests to me, that possibly (just possibly) the problem might not be related to the speedo unit itself, but the electric sender unit somewhere in the bowels of the engine bay.
"Is there a fuse perhaps hidden somewhere I might have missed, or has a wire dropped off the speedo sender", I ask myself ?
If someone has any trhoughts on the matter (like where I might find the speedo sender), I'd be grateful to hear them !
Thank you ...
Thank you ...
