So if the chassis and axle are ok does that mean the axle can be adjusted to make it symmetrical?
Phil
If the chassis and axle are ok there is no need to adjust the axle as its already symmetrical(in alignment with the chassis). The problem is the bodywork(I think)
It seems to me that the car has been involved in an accident that damaged the body work knocking it out of alignment with the chassis(and rear axle). Perhaps badly fitted replacement panels are to blame, a good mechanic/body shop should be able to tell you for sure.
