Hey im finally get rid of my Stilo "Blue" and upgrading to an abarth stilo.
I have a few quick questions as im going to view today.
What should i look out for? its a 2002, selespeed model with 60k displayed. i know the gearbox can be an issue but what exatcly can go wrong and how can i check?
Also insurance, my best quote was £1900 does anyone know of a way i can bring that down... any secret insurance tips
im 19 been driving for nearly 2 years but have 0years no claims bonus. no accidents or convictions.
Any help would be greatly appriciated.
Thanks. Jon.
That's an astonishing insurance cost - I'm imagining it must be about the same price as the car itself.
Here in NZ the insurance costs less for my Abarth than for my 500. It seems to be loaded based on value of the car and driver age. Performance of the car counts for very little! My insurance when I was 21 was about $500 (£240) for my Uno Turbo.
Anyway - back on topic - it isn't really the gearbox that gives trouble - I think it's more likely to be the clutch. As it gets near the end of its life, things get jumpy as you try to park. Moving off may require lots of revs, and the 1-2nd gear change can be a bump, too. I think the job requires a dual mass flywheel replacement, so is quite possibly the most expensive clutch job you'll do.
It would be a good idea to take along a laptop, an ELM327 cable, and FIAT/
MultiEcuScan. That way, you'll be able to check for stored fault codes. For example, ignition coil faults/misfires.
The interior suffers from sticky plastics in the lower half, plus the coating wears off the buttons. Both the stickiness and the buttons started off as a soft-touch rubbery coating - which either liquifies or wears off. Can be cleaned off and painted matt black.
Look for evidence of resprays, especially if you're buying a bright non-metallic colour such as yellow, red, or blue. Fade can be a problem, and resprayed areas will obviously fade at a different rate, which you won't see until a few months after you buy - so try to spot them first.
I just realised that these last two concerns relate to southern-hemisphere sun
Anyway, lift the bonnet and look at the wiring behind the engine and around the battery (there should be a cover over the battery - if not, be very worried, because the fuse box must not get wet). If the wiring looks like it's been removed and not clipped back properly, with missing coverings (wires hanging free, not bound with cloth tape), then it shows it's been apart and not put back together properly. Ask yourself why it's been apart.
Basically, you're looking for a car that's been looked after, and not suffered at the hands of hamfisted mechanics
-Alex
