hi guys need some info quickly if possible
my rear axle started to clonk again not only over bumps but on dead flat smooth roads as well, so i checked and this time it wasnt the bush, its the bolts to the chassis.
one bolt is missing and the other was loose, when i tightened it it just stripped the thread in the chassis - ive no idea where the other went it was there a couple of months back.
i think this damage was done when i purchased the car back in 2010 as it failed mot on the bolts then they put the wrong bolts in then and must have damaged the threads.
anyways, i need to know the thread pitch and size bolt i should replace them with, its a fine thread so im guessing about a m16 thread. could someone also tell me the size of the bolts, i will take it 1-2mm larger but need to get the tap and bolts from screwfix in the morning. im going to replace all 8 to be safe now.
thanks guys
roy
thanks guys
roy
