ive bought mine from the same place Peat has linked. infact, I just ordered another as I only did the one last time. They are pretty quick, so if you drop them an email, they will probably rush two out for you.
They are all over ebay - £2.99 - I've fitted mine - very easy to fit the blanking plate - just put it in in place of the thin steel gasket at the EGR VALVE END OF THE FLEXI PIPE - basically you have to undo only two bolts to do this - I've read about people thinking they might have to drill a hole in the blanking plate due to trick the ECU into thinking its not been blocked so as not to trigger a fault warning -nonsense - I've had no such issues - the ECU does'nt even notice you've done it - so there you go - my diesel engine is now a NON SMOKER - & I reckon it should now be more healthy in the long run - for having STOPPED INHALING stinky SMOKE......
