I thought I would share my bit of bad luck this week.
My turbo charger stopped working. There is lots of smoke under heavy acceleration & no power & no nice high pitched whirring noise either.
I called the AA to check it out & they had a quick look & came to the conclusion the impeller had jammed.
So luckily I thought, I have AA parts & garage cover policy. The AA took the car away & dropped it off at a Halfords Autocentre, (AA recommend dealing with Halfords under their garage policy). 3 days later the garage stripped th turbo charger out & inspected the turbo with AA & came to the conclusion the impeller was damaged due to impact. The only way this could happen is if something got into the airpipe. So this type of failure is not covered on the policy.
So now the AA have stuffed me by taking my car to a garage I wouldnt normally use, they have pulled out the turbo & then have walked away. I now have to pick up the cost to put it back together or continue the work with the garage.
Halfords want either £750 for a reconditioned turbo with a lead time of 2-3 weeks or a new one for £1100 with a lead time of 1 week.
This combined with hire car costs is almost not worth the cost of the car.
I have at least managed to convince the garage that I will buy the turbo & they install, if I do not take a 1 year warranty on the work. So I have found a turbo from a breaking fiat off ebay for £70. This combined with installation should take me to about £350. Although this option is high risk as I dont know much about the turbo I am buying.
So to conclude, I thought I would just give a heads up, if anyone else is considering getting a parts & labour policy with the AA, I wouldnt bother as your better off without it.
