I've just tried to open the drivers door on my Stilo (2003 1.6) and it's stuck solid. To make it worse it's parked on a narrow driveway with walls either side so scrambling in is not easy! The button comes up when operated by the remote fob, and all the other doors open fine. I tried operating the lock manually but that is solid with no movement either way, unlike the passenger side which works as expected. Operating the internal lever has no effect at all. I've tried running the engine in case it resets anything, but no luck so far.
I've searched for similar threads but none match this problem with the stuck solid lock. Any suggestions?
