Hello to all,
first I'd like to say how great this forum is! I've been a regular reader and found a ton of useful information - did some of the DIYs and bookmarked even more, because I'll surely be needing them.
Until now I haven't had a problem that I couldn't fix just by searching this forum, but the time has (sadly) come; as I stated in the title, I get a weird clonking noise from somewhere in the left wheel arch when going into a right-hand bend on an uneven road (and a very mild pulsating feel on the steering wheel (I have the wheel on the left since I'm not from UK )). I can not replicate this sound on a smooth road (in a right bend) no matter how hard I try - there also is absolutely no sound from the underside when going straight but on bumpy roads or going into a left-hand bend (no matter of the surface type).
I searched this forum and found out that drop links and tie rod ends are a common problem - I thought great, I'll just order these parts and get rid of the noise in no time. Problem is, I removed the wheels and checked the drop links and tie rod ends, just to be sure - they have absolutely no play in them! In pulled and twisted in every way imaginable, but with no success. I checked the tie rod ends with wheels on also, when the weight of the car is pressing down and I still didn't detect any play in them. That's why I decided to open this thread, if anyone has a clue what the problem might be.
I must add that I also checked front brake calipers and everything seems in place, so I don't think the rattle is coming from them.
The car in question is a '07 Stilo Multijet with 102000km (63379miles) on the clock and has been regularly serviced.
