- Nov 12, 2006
- 23
- 6
OK, so I had the old jubber problem etc with my 1.6 16v 51 reg stilo. The garage said the fault says 3 injectors but it could also be the ECU. I saw on the forum here how to test the wiring and injectors and each injector gave me a reading of 15 ohm's, so I thought it must be the ECU. Sent it away and the chaps say its perfect. So, do you think I should remove / replace the injectors or just sell the car? Its only done 44k. Is it easy to remove them and are they expensive?
Stephen
Stephen
