i agree slamming the car doesnt automaticly increase handling and decrease roll.
but find me a set of lowring springs with standard or lower spring rates and ill shut up. they all have higher ones, reducing roll...
but ill say it again
. get some fully adjustable coilovers and set then how you feel best. ive drivin mine for months set near the bottom of adjustment and ive not got a scratch under the car
it is completely true though that lower does not mean better. i know set to MAX drop my car does not handle as well as around 70mm drop. so thats where i try and keep them if im using the car daily. but even on max there not worse than standard it just gets quite stiff
. so it then again becomes personal preference.
i honestly beleive that if people want there car scraping the floor than thats up to them, if they dont fine
and 18" wheels are not going to absorb **** roads. but they also reduce tyre flex a huge amount which then allows the suspension to do what its designed to do. so for this its again personal preference as to comfort over handling....
also to quote YAMPUG.
"adjustable coilovers are not designed to be used to make your car sit lower or higher so you can think it looks pretty. if you lower it your springs are going to be so squashed up they won't work and if you higher it they won't do **** all.
Shadeyman, AndyRKett liked this post"
lowering the car does not even slightly squash the coil......... it lowers the lower attachment to the strut so slides the strut further up into the spring. the compression on the spring doesnt even slightly change
and although there not designed to slam the car, it does allow you to lower the car and increase the damping to stiffen it up.
also this is what i use for camber adjust on mine
http://www.monroeshop.co.uk/front-monroe-magic-camber-kits--fits-fiat-stilo-192-18-16v-192xc1a-pn-mc110-pair_p22292924.htm
propperly set up for camber and tracking
