philwilson
Hi to you all, i have just aquired a 2004 Stilo 1.4 16v. The car runs absolutely perfectly but the speedo, rev counter and engine temp gauge dont work. The fuel level indicator does work. I sent off the clocks to be tested and was advised that there is no problem with the clocks and that the problem appears to be that no signal is being sent from the ECU. The clocks do appear to power up ( the needles move when ignition is switched on) Does anybody have any ideas how to rectify this problem and if so is it an easy fix ?
Many thanks in anticipation, Yours, Phil Wilson.
