Hi everyone,
Seems like Screen washer pump is not working and I need some help on replacing it.When I try to operate the washer, only the wipers work and no screen washer is sprayed on to the screen (Both Front and Rear Screens).There is no sound of pump working and the fuses are all good.It was working till last weekend so I believe its the pump that need replacing as resovoir is filled up to the brim.
I had a look yesterday and it seems like the resovoir bottle is only held by 2 nuts and bolts one on engine cross member and the other on the inner front offside wing panel.Can someone please confirm these are the only nuts I have to undo to wiggle out the bottle (and the connector of course ) or is there anymore? Furthermore if I manage to syphon-out the washer liquid, is there way that I can remove pump, working blind by just pulling it upwards or outwards from the bottle? your answers will be highly appreciated.
