Unfortunately it happened quite a bit this morning driving 4 hours from Barnsley to Portsmouth. It was only gently. It happens only up inclines, doing about 60/65mph and lightly increasing throttle. Now i'm thinking it could be a fuel pump issue. Could i be on the right track? Whats the more likely cause, the pump in the engine or the tank? I had a filter and oil change using original filters. Also an EGR valve clean and my mechanic said the solenoid seems to be working fine. As i had this problem with my last engine the culprit must be a part that hasn't been changed. Thats why i suspect the fuel pump but thats if my mechanic used my original one....do they come with/part of engines? Then theres the pump in the tank. The MAF is new. Am i on the right track?
By the way its more of a judder.
Phil
Phil
