- Oct 20, 2007
- 4,940
- 744
Hi, my 1.8 stilo seems to have bit the dust, now i remember a thread about fitting alfa twinspark cams as they were the same as c&b ones ect.
can anyone tell me a few things without the usual. why bother things and dont worry insurance is also sorted.
can a 2.0 alfa engine fit in the car, running off my ecu, the spark is a wasted spark so althought it has 8 plugs it only uses 4 coils same as the stilo and runs the same variator. and all the fiat sensors will fit in the alfa block BUT the only thing i can see holding the plan back is...
Will my gearbox fit on the alfa block. (if it truely is a fiat block im sure it will)
and do the alfas use the same maf/map set up as the stilo?? ive read they run maf and stilo runs map but i want to make sure as if there the same i honestly cant see why it wont run.
if the above wont work ill just go for the 2.0 block with my 1.8 head and 2.0alfa cams ect just to get my head and throttle ect on there. but id rather just drop a 2.0tspark in...
any help at all with the project would be great and thanks for taking the time to read this!
