hi all,
FIRSTLY I APOLOGISE FOR THE PICS IN THIS POST, THEY HAVE POSTED UPSIDE DOWN AND SIDEWAYS AND WHAT NOT AND I DON'T KNOW HOW TO FIX IT :yuck:
I've been suffering with water getting into the oil for quite some time, and i've really been ramming my head against a wall trying to find out the solution to the problem. It isn't the head gasket (thank god) seeing as my coolant level has been constant for the months and months while this has been happening,
Recently while driving along the motorway, my engine cut out. The electronics were still on however as i drifted over to the hard shoulder. The car started up again no problem however. I called the AA guy and he plugged it into the diagnostics and didn't find ONE fault. He said he double checked all the sensors ETC and nothing came up whatsoever. He advised it could be a crank sensor problem.
After chatting to my old man about the problem he said he went through everything with his Citroen Picasso. sensors were changed, new parts were ordered and still they never got to the root of the problem. Eventually he took it straight to the Citroen dealer and was told pretty much straight away it was the fuel filter. He had it changed and no more problems have arisen since, so i'm guessing my fuel filter could also need changing?
anyway, i whipped the bonnet up this morning to check the air inlet valve and give it a clean. When i took the intake pipe away the inside was brown and wet. There was even a small puddle of browny liquid at the top of pipe.I had a look in the breather hose and it was same all the way down. A creamy browny oily looking substance. I checked the intake on the front of the car and found a small box just beneath it. I have no idea what this box is for but i found it snapped off from the pipe, leaving a gaping hole for water to enter the air intake.So at last! it looks like i have found the reason for water in my oil. It's obviously entering the oil from the breather hose! I've added pics here to make what i am saying clearer.
what would be a good step to take from here? should i clean the whole air intake myself and repair the mystery box back onto the pipe?
or should i just get a whole new air intake just to be sure? If so, what price am i looking at? i've always wanted a BMC CDA, is it worth getting one of them or another aftermarket piece instead if the price isn't far off?
cheers guys!
cheers guys!
