- Nov 12, 2006
- 23
- 6
Hi, Can onyone tell me how to "Virgin" an engine ECU. I want yo put in a second hand one off of Ebay.
Just had a thought. What if I buy the old cars ignition key at the same time, would that sort it out?
Sorry im confused...why wont a Used ECU work??
I would have though new ones were supplied virgin!!! Oh why do car manufacturer's make everything so complicated.
hi can u tell me how virginize a engine ecu for fiat stilo thanksno, that wouldn't work - you would need the bodycomputer, ecu, keys, all locks from a donor car with the same configuration as your own car.
Virginising your ecu would be much simpler - if it's a iaw5nftx for a 1.6 stilo i can do that for you, pm for further details please...
i bought expensive equipment to virginise these ecu's - you will have to revirginise quite a lot of them to recover your costs....
Just for one ecu it's much cheaper to have it done by someone with the proper tools...
virginising will not alter the 1.4 ecu map but i'm not sure your plan will work - the communication with the bodycomputer might fail when the immo, mileage data etc. is written on other locations inside the eeprom....
A remap won't help you either as this only changes the flash data with the maps.
Is it possible to clone an ecu? I have a spare with a manual map, mine has the MTA box so I could do with a clone to use as a base for remapping and the original as a back if I need to return the car to standard.
So basically the engine won't start with any of the two ecus??
Will the 1.4 engine not run of the 1.2 ecu at all?
EDIT: Sorry I meant remapping the 1.2 ecu to suit the 1.4 engine not remapping the 1.4 ecu. Would the 1.2 ecu run the 1.4 engine?
