I had some problems with electrics now and can't connect to engine ecu.
I did scan for models (F11 Scan) and shows all (ABS, Body,...) no engine ecu. Body shows CAN error on line W err. #P1028. It did connect before and all was fine. I was playing with injector actuators 1-6 and then all hell came loose on dashboard with all sorts of trouble. I tought ok battery problem connected to Golf's TDI battery without luck. Recharged the battery also no luck there... or maybe those were old errors I'll go check if I can connect now on engine ecu.
err. P1028 is a strange one doesn't exist on any list I could find?!?
Affraid I killed ECU somehow.
That's a job for super expert.
