So to speak yes I'm struggling to keep boost down, only because I'm injecting too much fuel for the turbine size I have, to keep control above 20%, so even at 2800mb I can get boost creep, I can request higher boost pressure or lower requested fuel at the revs the creep occurs.
I am already at a higher power level than what I had planned when I started the hybrid turbo.
If it still creeps at 2850mbar I will reduce fuelling to regain some vnt As 27psi is a self imposed limit I don't Really want to cross for reliability(this is my daily driver after all )
I have seen you in a few threads on alfaforum did you ever get your injectors sorted?
