Hey folks!
Wondering if someone could point me in the right direction with this before spending loads on the car (again!)
Stilo Abarth, 2.4, 02 plate
On Monday the car would not start, just turning over and over and over. Removed and replaced small fuses under bonnet and reset ECU by removing the battery for a while.
Started fine, no issues until the Tuesday!
Same thing happened, but it is refusing to start. Hooked upto registered Fiat ECU Scan today and got a mahoosive list of error codes (below) Also, there is a slight buzzing noise coming from the ECU (top right of engine). Have tried unplugging this and reconnecting with no sucess.
Thanks in advance!
SCAN DTC
Scanning ...
Engine
Bosch Motronic ME 3.1 EOBD (2.0, 2.4)
ISO Code: 7C 86 29 01 01
Errors found:
P1135 - Preheating resistance 1 above catal.
P1653 - Phase variator
P0340 - Camshaft position sensor
P0571 - Brake pedal switch
P0201 - Injector Cylinder 1 (1)
P0202 - Injector Cylinder 2 (1)
P0204 - Injector Cylinder 4 (1)
P0205 - Injector Cylinder 5 (1)
P0203 - Injector Cylinder 3 (1)
P0443 - EVAP circuit (4)
P1654 - Modular manifold
P0135 - Preheating resistance 1 above catal.
P0141 - Preheating resistance 1 below catal.
P0120 - TP Sensor/Switch (1)
P0115 - Engine Coolant Temp. (1)
P0638 - Motorised throttle (circuit)
Gearbox
Marelli SELESPEED CFC209F Automatic Gearbox
ISO Code: BC 07 83 01 1C
Errors found:
P1760 - Brake pedal switch
U1700 - CAN: Body Computer conn. fault
U1701 - CAN Network (NCR - NCM)
P0720 - Transmission/Gear Sys (12)
U1706 - Gearbox > ABS data line
Body
Marelli MF Body Computer
ISO Code: 40 83 8C 80 A4
Dashboard
Visteon Instrument Panel
ISO Code: 32 83 0E 01 19
Errors found:
B1001 - Instrument panel
B100C - Water temperature gauge
B100E - Speedometer
Dashboard
Marelli Connect (NAV)
ISO Code: B5 83 83 01 91
Climate control
Marelli climate control
ISO Code: 34 83 04 01 91
Errors found:
B1902 - Windscreen flap actuator
B1904 - Left mixing actuator
B1926 - Climate control compressor
B1927 - Pollution sensor
B1906 - Feet/chest motor feedback
Other
Driver's Door (BITRON)
ISO Code: 86 07 04 80 E6
Other
Passenger's Door (BITRON)
ISO Code: 89 07 83 80 68
Other
Valeo parking control
ISO Code: 3E 83 02 80 98
Other
COMPLETED
SCAN (F11)
Scanning ...
Engine
Gearbox
Body
Dashboard
Dashboard
Climate control
Other
Other
Other
Other
COMPLETED
Thanks in advance!
SCAN DTC
Scanning ...
Engine
Errors found:
Gearbox
Errors found:
Body
Dashboard
Errors found:
B100E - Speedometer
Dashboard
Climate control
Errors found:
Other
Other
Other
Other
COMPLETED
SCAN (F11)
Scanning ...
Engine
Gearbox
Body
Dashboard
Dashboard
Climate control
Other
Other
Other
Other
COMPLETED
