Does anyone know the arrangement of the drainage holes at each end of the plenum chamber underneath the front windscreen? Mainly I would like to know if they get easily blocked or not, and how to access them if they need to be cleaned out.
Many thanks for this. Really helpful. I'll clean them out as soon as I can.You can easily clean them; just remove the plastic around (above) wheel(s) and look for
"square" shape hole.
Also you may look at:
http://fiatisti.hr/forum/index.php?topic=24506.msg440154#msg440154
where I described how to do it with photos. Hope you will understand a bit of croatian.
...i suggest to do it every year if car is often under the trees...
sorry think im looking in the wrong place!! haha. mine are indeed near where the door closes.
