Chaps. I'm a bit fussy over the lines of a car. I like panels to meet correctly and so on. Now, I have noticed on some Stilos the bonnet seems to be lower over the headlight than the wing. Maybe only a few mm but noticeable, on other Stilos you can see clearly this shouldn't be the case. What causes this? On the cars with the issue I have noted that everything else seems OK, headlights appear OK as do wings, but its hard to tell if the bonnet is slightly out of line, is this a common but easy to correct thing?.
