Hello,
I own a Stilo 1.6 16v 11/2001 about 90.000miles and I got some troubles with it.
When it's at low rpm (about 90 degrees temp) at 700-800 rpm sometimes it gets lower and the car is trembling.
When that happens, either I accelerate it or I open the AC it gets to around 1000rpm and everything is cool.
I attached the Fiat ECU Scan small diag log here as I couldn't attach the CSV file...
READ PARAMETERS:
Engine load: 15.250 Kg/h
Spark advance: 2.3 deg.
Baro pressure: 998 mBar
Injection time: 4.418 ms
Throttle position: 4.8 deg.
Misfires (2): OK
Lambda signal 1 (Pre-Cat.): Closed Loop
Engine temperature: 69 °C
Air temperature: 39 °C
Manifold pressure: 445 mBar
Engine speed: 842 rpm
Lambda 1 status (After-Cat.): System lean
Lamda signal 1 (After-Cat.): Open Loop
Desired idle RPM: 831 rpm
Evaporation control valve opening: 3.8 %
Cylinder 1 timing: 0.0 deg.
Cylinder 2 timing: 0.0 deg.
Cylinder 3 timing: 0.0 deg.
Cylinder 4 timing: 0.0 deg.
Mixture correction learning value: 1.031225 %
Lambda sensor 1 integrator: 1.091050 %
After-Cat. lambda sensor signal: 0.175 V
Pre-Cat. Lambda sensor signal: 0.336 V
Lambda 1 status (Pre-Cat.): System lean
Lambda sensor 2 integrator: 1.026450 %
Knock sensor signal Cyl. 1: 0.717 V
Knock sensor signal Cyl. 2: 1.235 V
Knock sensor signal Cyl. 3: 0.732 V
Knock sensor signal Cyl. 4: 0.839 V
Coil 1 charge time: 1.804 ms
Coil 2 charge time: 1.550 ms
Coil 3 charge time: 1.550 ms
Coil 4 charge time: 1.550 ms
Air pressure (calculated): 511 mBar
Throttle angle: 0.0 %
READ PARAMETERS:
Misfires (2): OK
