ok chaps, I done it, I bought the Blue Stilo on Autotrader!
Went to see it today, I didnt think I would do as I hadnt been able to get in touch with the garage to see if they were open. Anyway, we had a plan to go out, so I just gave them a quick call and they were open. LONG way for us to go, but went anyway and had a good look.
ok, its not perfect, or mint, but it does seem very good, certainly for the money. Its got:
Skyroof - works-maybe recently repaired as headlining bead is in the boot.
Air-Con - does work, can feel colder air, can hear unit kick in etc, just needs a regas.
Cruise Control
Decent Seats
Claw (?) Alloys
rear spoiler
3 owners
MOT till Feb 2013.
I had to get him down £100 on price as no remote fob, so thats my first job. It will come with two new front tyres as those on there were pretty much slick.
Everything seemed ok at first (wait for it). Checked the interior-pretty clean, no leaks down the pillars. FIRST thing I checked was SkyRoof-perfect. Then Air COn-after starting engine, perfect. Engine very cold, looking at brakes hasnt been driven for at least a few days, but started fine and idled fine. left it running whilst I checked all the electrics, everything works and seems to work pretty well.
Engine bay seems good, engine seems to idle ok, no dodgy rattles that I could hear-all service areas were clean and topped up, oil was good also - no detectable leaks and looks like a new fuel filter. RAD seemed fine, but couldnt remove any covers to check battery or engine (more on that in a minute).
rear boot has minor bubbling around the lock-presumably the last owner didnt have a fob either. A tiny paint chip just up from the lock also, but nothing bad. Around the car, its generally good. almost invisble scratches/marks that SHOULD TCut out we will see, worst part is the rear window-curve scratch to the glass form the wiper-must have had something caught, so will try some glass scratch remover on that but i wont hold my breath-its low down, and not really a problem for me since i plan to tint the windows anyway.
very VERY minor dents on the passenger front wing near the headlights, ill see how I feel about that later so may get fixed. Need to adjust the bonnet stops too-its just a smidge too low. I noted the rubber around the skyroof was worn and poor, but i have no point of comparison, all i know is I couldnt see any evidence of water leak, so finegrs crossed its a tight seal.
Exhaust looked good front to back, brakes ok, slight sticking on one of the rear calipers as I pulled away but ill forgive it as its been stood (evident through surface rust on the discs).
ok, so, took for a test drive. Clutch felt pretty good, brakes very good and it drove, i thought, superb. The tray under the car was hanging a bit slow, and i could hear that knocking slightly - couldnt hear/feel any knocks from either corner and the road was plenty bumpy to give away anything worth noting. I felt the drive was tight, and the engine appeared powerful with no hesitation or smoke etc etc, just felt good. Took it for a pretty long drive, fast roads, town, slow roads, streets etc, felt good, was very happy with it. Got back to the garage....
parked it up, and I just wanted to have a bit more of a play, just to be sure. I had stopped the engine, gone round the car to check for a smell (rear brakes, but clearly working as the disc was now clean). got my other half to start it and rev it-no smoke. played with the electrics (engien running) all good still. stopped the engine, i hopped in, and wanted to try just one more time, and surprise surprise, wouldnt start. In fact, couldnt turn the key.
so...couldnt turn key, when i did, it couldnt start-was trying, but it was no doubt the battery, because after a couple of tries the dash died, then reset itself (the clock) and that was that!
Im not too worried-the chap says he has to fix it otherwise he cant sell it, so thats the agreement-alternator, battery whatever it is he has to fix it. BUT, even so, am I on the right track here...battery? Just seemed strange that I could go for a drive and do all that playing only for it to die UNLESS< he had already charged the battery prior to me arriving (noted battery charger on the car next to us), so this indicates either a faulty alternator or battery.
what do y'all think?!
I am regardless, very excited, and look forward to fixing the various niggles
