Hi all,
I have a Fiat stilo 1.8 16v 2005 that has a weird problem, the clutch works fine but sticks at the bottom when fully pressed down, if you can convince yourself to leave 1" before the fully pressed down position it is fine but sticks most times when fully depressed (BTW it is not the carpet). I used to be a mechanic many years ago but have limited experience with clutches on Fiats so any advice would be appreciated before I end up taking the gearbox out. Got a nasty feeling this might be what needs to be done? But fingers crossed.
I have removed the pedal noise reduction cover and I notice that there are two components + switch that the clutch pedal operates can anyone tell me what these are called? And if there is a common problem with these? I could take a picture if needed
I did give one of the components a squirt of wd40 last night whilst examining the clutch pedal operation ,but it didn’t seem to do anything BUT the pedal worked fine for 50 -100 times this morning before it started sticking again which started again after a few miles trip when reverse was selected, air in system? Clutch slave cylinder? Coincidence?
From what I can gather from reading this forum and other posts online this model seems to have an internal clutch slave cylinder is this correct?
Any help knowledge on these motors would be greatly appreciated, struggling to get a book on this car although I am trying to download one as a type this message.
Sorry for the millions of questions J
