I've changed the oil on my mini a million times before so how come it went so very very wrong with my 1.2 Stilo lol.
1. Buy my oil.
2. Go to Halfords to buy an oil filter.
3. Buy engine flush, as the oil was pretty manky (weird too because I hadn't even done 12,000 miles on it, although thats been over a year the oil was in the car)
So run the oil up to temperature, get the car up on ramps, check out the sump plug.... damn 12mm Hex, I only have up to a 10mm. So off a trudge to Halfords, wish I'd checked on here first for Sump plug size.
Get home, repeat, get car on ramps, run flush through for 15mins, then get my oil catch tank positioned, loosen sump plug and oil starts to gently flow, excellent, finally something is going right today.
Then.... BANG sump plug drops out and about 50 gallons of crude oil starts to spill out everywhere. I tell you 2.8litres of oil looks like a hell of a lot when your failing to catch it in the catch tank.
Lol, still alls well in the end. Changed the oil, and filter (eventually) and the drive is largely cleared up thanks to some drive cleaner and the pressure washer.
1. Buy my oil.
