Changed mine few months back..as having problems with fan only blowing on very low speed and would now and again fire in to life ..mine was climate control type even tried different display control panel which made no difference ..the blower motor has to be from a climate control type system as they use different fans 4 pin type on climate control fan and does not have resistor pack but a circuit board with in the fan it is possible to take apart but as sealed in resin difficult to test you can check circuit board for basic bad joints and signs of visible damage..
Sourced mine from breakers after checking it was from climate control system..also be aware that the fan for climate control was updated to Denso not sure what year they changed this ,,which I have in now and requires an extension on the wiring for it to reach as the plug connector on the denso fan is in a different postion fiat do make an extension cable..I am happy to work on electrics so with the correct gauge wire extended mine myself ..there is other threads on here that give more detail which was a great help when I did mine as the fan is awkward to remove but possible with removal of steering joint and strapping up clutch pedal in foot well..
