Technical What else if left to try fix my stilo?HELP PLease
How much pedal travel was there between when the clutch began to bite till the pedal was right up/car stalled?
Have you noticed the biting point moving further up over the time you've owned the car?
not much at all, once the bite came in, the clutch was right up not long after that, because the car stalling caught me by surprise.
ive not really noticed anything to be honest, ive only owned the car since january.
what i have noticed is that when changing from 1st to second and sometimes second to third, when i release the clutch pedal the car does something which i cant really explain. its as if it hesitates for a split second when the gear is changed. it didnt use to do that before.
thanks
thanks
Something doesn't sound right about your clutch,to me anway. You might just have an air pocket in the clutch line which is causing it to "hesitate" :confused:
Try driving it in 2 or 3rd gear and apply the throttle prgressively and see if the revs showing on the tacho match what speed you are doing. When my clutch failed on me I could literaly rev my car while it was in gear!
when i try to put m foot down on 2 and 3rd gear, or any other gear to be honest the only starts to pick speed, once it goes past the 2000rpm, before that it just sort of lags.
