hi there, i have just come out of the fiat dealers and they have diagnosed what is wrong with my car (loss of power + high fuel consuption), plus everything else was checked too, all for £35, so far so good. HOWEVER, these are the results.
wheels and tyre
OS front - New tyre required - £110.40
OS rear - New tyre required, punctured - £110.40
NS Front - New tyre required - £110.40
OS front - wheel badly buckled - £344.84
Clutch - clutch is heavy, requires renewing soon - £451.86
Air filter - air filter box all smashed allowing dirty air into engine, requires replacing along with airfilter. £224
Air mass - suspect air mass meter causing engine problem due to contamination by broken air box, need these repairs doing first but may require further diagnosis afterwards. - £176.51
intake pipe between air mass meter and turbo damaged allowing unmetered air into engine this could also be contributing to the enginne problem. £57.80
Battery - battery insecure, too big for car and cant be held in place correctly, this is now an mot ffailure. - £102
could anyone tell me where the best place to get these parts from is, and for a reasonable price, im a student, so i definitely cant afford £1600.
the most important right now are theturbo hose, the air filter box and the air mass meter. the rest i will get done in time. thanks
i have a fiat stilo 1.9 mjet 120
would i be able to fit a vauxhall air filter box in my car since they have the same engine?
and if so, can someone tell me which would be the correct one as there seems to be a few on ebay.
thanks
wheels and tyre
thanks
