P0101 - air flow meter signal
P0111 - intake air temp. (2)
P0045 - turbo actuator command
Hi there people, im having trouble with my car. It has high fuel consuption and loss of power. I decided to disconnect the Air Mass flow sensor to see it would make it any better. there was no difference to the power, but the MPG went down by about 10mpg. After i connected it again these were the codes that came up,
P0045 - turbo actuator command.
i decided to clear the codes with fiatecuscan, went for a round trip of 200 miles and the codes havent come back up. so shall i actually buy a new MAF sensor?
also i have changed the egr valve, new oil filter, new fuel filter, new air filter, and changed the oil.
can someone tell me what can be causing my loss of power, what i can do to fix the codes and what they actually mean? iev got an appointment booked with fiat on thursday, but wanna see if i can fix it before then.
stilo 1.9 mjet 120
thank you very much.
stilo 1.9 mjet 120
