just a update, job done again!!!
sadly the new axle i was going to use as written of by the breaker and his plasma cutter, he offered me a discount but the axle is scrap, he cut the blooming bush holder!!!!!
so i had another look around and decided to do my axle again, the pulley kit that shadyman linked to was EXCELLENT!!!!
i had a collar made up to allow the bush to pass though un obstucted (thanks colin) and used my new press tool.
I originally tried to press it in with the three legs on the pulley but when the axle is still on the car as was in my case two leggs were much easier, and it reached with the supplyied extenders.
I got the shop4parts bushes this time (trusted part from experiace), they were oversized like the oems but the puller made mince meat of it, infact i didnt even bother taking down the outside diameter at all.
It was slow fiddly work winding / unwinding / winding etc but it went in with very easily, the job would be easiler with the axle removed but who wants to make more work for themselves.
Ive changed only one atm (ran out of time before having to go to work) and am planning to change the other again as i really dont trust the original supplied bushes, from experiance they usually blow straight away if fitted incorrectly not 100miles or so down the road so its coming out.
The car is nice and tight again on the back end, and most of all quiet....
When i do the other side i will take some piccys so you can see the puller in action and the bush being changed in situ...
i personally think that fiat recomending the axle change is down to the fact they use loads of heat when putting the bush in, in my case ive never applied any heat -im more worried about the rear springs now as they have been in and out so often they are only now covered in waxol and no paint lol.
roy
