Just washed the car (by hand - no hose pipe) the battery was disconnected, reconnected the battery and the main beams came on straight away and there was a faint hissing sound, tried to start the car and it said "Car security"
So I thought, must be a drop in voltage so il wack the jump start on. Jumped the car no problem however the main beams would not turn off.
Quick trip round the block, took the key out only to have the engine still running
Finally stopped so I thought I would re start the car (had the problem before but replaced the battery and all was fine) once again, wouldn't start so I jumped it a second time. Same headlight problem. Left it to run for a few minutes only for the cab to smell like burning! Tried to turn the engine off but the key just came out, frantically pulled the negative but the car still ran! Pulled the positive and still running. Had no choice but to deliberately stall the car. Smoke pouring from the engine (not battery) which may have smelt plasticky but not sure
Bit afraid to start it now so what should I do? Any idea's on cause/solution?
Just for reference: 3 door 1.9jtd 02 plate
Many thanks,
Mike
Many thanks,
Mike
