edwin884 Member Joined Dec 26, 2011 Messages 211 Points 50 Mar 22, 2012 #1 The noise is coming somewhere from the cam belt. It only appears when the revs go up, from about 1200rpm, no buzzing noise on idle. What could it be?
C cris1117 Established member Joined Dec 21, 2007 Messages 786 Points 191 Mar 22, 2012 #2 You had better hope it’s not the cam belt or tensioner aboutto go bang.
OP OP edwin884 Member Joined Dec 26, 2011 Messages 211 Points 50 Mar 23, 2012 #3 The cam belt and the tensioners are only 2 months old (SKF)! I found on the net that it could be the tensioner of the belt that drives the alternator!
