declanshood
- Mar 7, 2012
- 11
- 6
Hi had my stilo 1.6 16v for around a year now, it had a problem were it would randomly cut out but especially when coming to a stop at junctions or when idling the revs would go up and down then after a while it would cut out.
Along with these problems were that it had slight flat spots of power in the rev range and sounded pretty noisey on start up from cold.
It rarely threw up the engine management light so it was hard to code read the problem with a diagnostics tool.
When i did manage to track down the problem i had a open circuit on injector one and a cylinder misfire on cylinder 2. I replaced the injector on cylinder one with a brand new part and fitted a new coil on cylinder 2 and it seems to run alot smoother.
The car has only done 26,000miles but its had a timing belt done by the previous own (although the car only had 18,000 miles on when i bought it last year??) Anyways i fitted a camshaft sensor and retimed it using the previous mechanics timing marks.
The problem is that it still cuts out when started from cold occsionaly and the revs still hunt up and down and often cause it to cut out, I have no idea what else to check so i basicly think the timing is a tooth out,
Anybody have any timing keys they would sell me for the 1.6 16v petrol engine? or any ideas what my problem could be?
VERY sorry for the long read!! Any help would be great! thanks!
