Remove lower steering cowl by undoing 3 small Allen key bolts underneath.
Pull down and remove. Tight and fiddly if wheel/ airbag left in place but can be done.
Look up behind steering wheel to front of top cowl, remove two Allen bolts.
Remove top cowl.
Lift up material cover at top of column and remove two Phillips screws from bottom of instrument panel.
Remove material cover and plastic trim,
Remove two Allen bolts from very top of panel.
Using flat screw driver, carefully prise down top of panel remove panel and top trim.
Remove clocks.
Very easy just take care
